1999 honda accord a/c compressor wont actuate
Old Jun 12, 2013 | 01:28 PM
Jamel Smith's Avatar
Unhappy 1999 honda accord a/c compressor wont actuate
99 accord a/c blowing hot air.... i jumped the battery directly to the compressor and the compressor works and the air blows cold....I reconnected the compressor plug and jumped the pressure cutoff switch on the drier....when i disconnected the plug from the drier the fan went off and when i jumped it with paperclip the fan came back on..... seems as if im getting power to the cutoff switch.... also i switched out the relay under the hood and no change in compressor status....
Old Jun 12, 2013 | 05:02 PM
I've moved this to General Tech where is blongs. Please read the posting rules in the DIY Section.
Old Jun 13, 2013 | 05:53 PM
You say "the fan" - which I read as one. So which fan is running - Drivers or pass side....also need to know is this a 4 or 6 cyl?
Old Jun 26, 2013 | 06:32 AM
Sorry for not getting back sooner..been working Hard....drivers fan and 6cylinder
Old Jun 26, 2013 | 06:48 AM
Suggest checking voltage on the single wire at the compressor connector.
Low or no voltage means either the ECU is denying ground to AC relay, relay has failed, or wiring fault from relay to compressor.
Old Jun 27, 2013 | 04:37 PM
Hk v6 6spd's Avatar
If the passenger side fan is not on it is either low on charge or the relay is no good I work at a Honda dealer relays and a/c clutch are most common
ak474u
May 4, 2015 11:15 PM
HondaSid
Jul 18, 2014 07:40 PM
MUFFRIDER
May 1, 2014 03:08 PM
Alimaxor
Mar 18, 2013 04:22 PM
markgm
Jan 21, 2010 09:41 PM
