gear shift stuck in park. cant start
Old Sep 15, 2010 | 12:20 PM
malachi_mez's Avatar
Default gear shift stuck in park. cant start
1998 accord, 4 cylinder automatic
Will not start, very difficult to shift out of park, when it does shift, 4th gear is lit up in green and P is lit up red, or then they both will switch color. Brake lights work but I did not try the horn. Will later today when I go by it.
Anyone had this problem? Any suggestions on what the problem could be and how to fit it
Thank you for your attention.
Brian Miami Beach 305-915-7520
Old Sep 15, 2010 | 07:59 PM
There is a shift interlock in the console gear selector mechanism which may be loose or shifted out of adjustment preventing the shift lock solenoid from releasing completely. You should be able to hear the solenoid movement when you step on the brake pedal (engine off).
Fix is to remove console and adjust shift lock solenoid mechanism per shop manual. You may be able to find use description from some of the download manuals from earlier model years.
letsclique
Jun 18, 2016 04:29 PM
moon-doggy
Jun 27, 2013 12:53 PM
d0n
Feb 4, 2013 08:45 AM
Ray Marrujo
Nov 26, 2012 08:01 PM
Jcaleno
Jun 11, 2007 02:55 PM
