Breaking that axle nut loose.
Old Dec 16, 2014 | 07:17 AM
  #21
James Glenn's Avatar
It is a 36mm socket. I just pulled mine off yesterday. I used a standard 1/2 drive ratchet and a cheater bar.over it. Instead of pushing down on the breaker bar, I used my shoulder and legs to push up. So when it did break loose, I didn't go flying. Good luck! Hope it helps!
Old Mar 17, 2018 | 10:56 PM
  #22
jimjdm's Avatar
Do yourself a favor and get the right tool for the job. With a 1-inch drive socket and a ratchet or impact gun, you will not give that nut a second thought, even if you do not bother to unstake it first. With the ratchet having a handle about 3 feet long, you are up to 300 ft-lbs with only 100 lbs of force on the ratchet. A decent 1-inch drive impact gun will have a max torque of about 1000 ft-lbs. Problem solved.
Old Mar 18, 2018 | 08:48 AM
  #23
irhunter's Avatar
Originally Posted by Half-fast
Bring it to a truck shop that has a 3/4 impact....
I was once breaking tools on my Accord crank bolt. Took it to a mechanic who had a 3/4" impact gun; still no luck!
Then, to a truck/dozer shop. They let me use their impact gun, while parked next to their shop, for free. But, here is the interesting thing. The mechanic handed me a normal-looking 1/2" drive IR gun...I told him about the 3/4" gun which recently did nothing to that bolt. He laughed and said his gun would be plenty. I just touched the trigger...and that bolt was out.
So, the right 1/2" gun was all I needed. He also had a fat air line and a compressor which was the size of my car. I don't know what psi he was running. I am not sure CFM matters much for an impact gun, but having your pressure over the normal 90 helps.
Roy
Last edited by irhunter; Mar 18, 2018 at 08:48 AM. Reason: Breaking tools not braking tools
Old Mar 18, 2018 | 11:25 AM
  #24
The Toecutter's Avatar
Roy
I've used my torch to warm up that bolt before a few times. It seems that everyone uses loctite on them. I've broken 3 extensions on that bolt on 3 different cars.
As for the axle nut, I just use my 1/2 inch Ingersol Rand impact. They come right off with it.
Old Mar 18, 2018 | 11:58 AM
  #25
irhunter's Avatar
Assuming adjacent parts can take the heat, cherry-red is nearly always the answer for stuck parts. But, most parts are large enough, or heat-sinked enough, to need oxy/acet to get them that hot.
Roy
Old Mar 19, 2018 | 07:53 AM
  #26
djkurious's Avatar
I have removed the bolt with a 300 foot-pound cordless impact wrench before with this tool:
Amazon Amazon
I have since upgraded to a bigger cordless impact wrench so the bolt comes off with a normal 19mm socket.
Old Mar 19, 2018 | 08:13 AM
  #27
irhunter's Avatar
https://www.amazon.com/Lisle-77080-H.../dp/B00RGNCV1U
Cool. I've never seen one of those before.
JonJon13926
Jul 13, 2013 11:51 AM
Doug Grellner
May 12, 2012 12:17 AM
ExpLo
Oct 21, 2011 08:10 PM
jimmy
Feb 2, 2009 10:14 PM
VI009DZ
Jun 19, 2008 10:57 PM
