Broken Axle shaft
Old Apr 7, 2009 | 02:43 PM
ColonelPanik
Default Broken Axle shaft
1991 Accord Wagon. 5 Speed. The drivers side axle shaft is broken at or slightly
inside of the tranny.
Any suggestions? The Colonel is really stuck. No matter how weird your
idea, lets hear it! I will try anything, ANYTHING I say!
Old Apr 7, 2009 | 03:34 PM
hondadude's Avatar
Do you mean to say the stub of the inner CV joint has snapped off?
If this is the problem...drill into the stub and tap it to be able to screw a bolt in...then use a slide hammer to pop out the stub
Old Apr 7, 2009 | 03:47 PM
ColonelPanik
Cool, any problem with metal from drilling getting into the tranny?
Old Apr 7, 2009 | 04:40 PM
Sure, if it's broken inside the tranny axle seal. Stuff that area with grease first, to catch the shavings. Or figure out some other way to prevent the shavings from going inside...
Old Apr 7, 2009 | 04:47 PM
ColonelPanik
Great job guys, Thanks /°_°
Afnan
Nov 19, 2013 05:52 PM
razcob
Dec 13, 2007 07:29 PM
nixalot
Jan 25, 2007 02:02 PM
HuYnHness
Jan 9, 2007 10:28 PM
amyandrew2
Apr 15, 2006 03:40 PM
