Broken Speedometer
Old Sep 27, 2007 | 04:46 PM
nrmskate's Avatar
Default Broken Speedometer
Ok, So i have replaced the VSS module, And still nothing out of my speedometer,cruise, or odometer.
So i ordered a Dash Cluster to replace the old one and see if this solves the problem.
My problem is, I have no CLUE on how to take out the old dash.
Ive taked the two screws out of the top of it and thats all.
Can someone help me with a tutorial and/or diagram?
Thanks ahead of time.
Nick
PS: 1994 Honda Accord LX
Old Sep 27, 2007 | 05:38 PM
deserthonda's Avatar
Default RE: Broken Speedometer
go to our DIY section top part 3 from the top, ( acc 5th gen infos and manuals)
Old Sep 27, 2007 | 05:47 PM
There is a shop manual for a 94 accord that you can download from www.hondahookup.com/manuals
The pdf is large, and it is interactive. You just have to click on electrical, and then gauges (23-134). There are also tests for the cruise control (23-298).
Did you read an error code for a failed VSS when you replaced it? Are there any error codes stored on your ECU (follow instructions from this link http://www.dhost.info/accordinfo/howto/cel.html)
You should diagnose the problem before throwing parts at it. I don't see how replacing the instrument cluster will fix the cruise control problem, but I would guess that the two problems are related.
Go through the electrical test in that shop manual to DIAGNOSE the cruise control problems.
jreniak
Oct 28, 2014 08:21 AM
pyaarawala
Aug 27, 2007 06:58 PM
mnvikings1973
Oct 25, 2005 01:58 PM
mnvikings1973
Apr 11, 2005 05:42 PM
pgopalak
Dec 17, 2004 03:30 PM
