Bumper turn signals is not working.
Old Jan 26, 2007 | 03:01 PM
kennilope's Avatar
Default Bumper turn signals is not working.
Hi. How do you fix the bumper signal lights. both of them are not working and causing my turn signal to blink very fast.
I look at it and it seem fine with the wire...
Need helps.. thanks......
Old Jan 26, 2007 | 03:14 PM
sir_nasty's Avatar
Default RE: Bumper turn signals is not working.
Have you tried replacing the bulb? typically when they start blinking fast it's just a bulb or a fuse problem (providing the wiring is ok) or just pull out the bulb holder and turn the signal on and put a tester in there to check for power, if no power then check your fuses
dustin3
Aug 17, 2011 04:52 PM
jalospride
Jan 4, 2011 08:24 AM
twisted95accord
Sep 4, 2010 09:10 PM
wsbowen03
Apr 30, 2009 02:46 PM
Codonah
Oct 14, 2007 08:58 PM
