Buying a 98 and need advice/help
Old Mar 11, 2012 | 11:52 AM
phoneguy44's Avatar
Default Buying a 98 and need advice/help
I'm headed to look at a nice and clean 98 EX 4cyl 5-speed with 140K. Owner listed the following in his add: new brakes, timing belt and water pump all the belts and gaskets were changed at 110k miles, no check engine light or any other lights.
When I go to look at this car tomorrow, what are some things I need to look at or pay attention to for this model ?
Thanks guys
Dennis
Alabama
Old Mar 11, 2012 | 11:58 AM
Well, it is a 5 speed so that takes out the worries on the auto trans.
In general the 5 speeds in this gen are solid. I would suggest taking it some place for a "buyers" inspection.....
Old Mar 11, 2012 | 01:27 PM
bensminger2003's Avatar
Just make sure there are no leaks and very important, look under the car the best u can and look inside each wheel well. Just basically check for any hidden rust or other possible hidden problems the seller may be hiding. Just to look out for you
Old Mar 11, 2012 | 03:05 PM
UhOh's Avatar
At parking lot speeds turn right then left. A clicking noise means the axle CV joints are bad.
~ $225 per side to have axle replaced if go to a shop. (OK to drive, till fixed)
clutch is an obvious one.
mechanic check is good, as said above, but if it's a long time (original?) owner that's worth a lot.
Old Mar 12, 2012 | 12:12 PM
phoneguy44's Avatar
Thanks guys for the advice. Drove 2 hours to look at the car yesterday and basically seller was a liar. Dings all over the car, none of the gauges worked including odometer, leaking oil in drive way after a 10 min drive. I talked to this guy 5 times before I made the drive, he gave inside and outside rating or 9.5 out of 10, said he'd take 4500 for it but when I got there, photos were not true AT ALL. Offered me 3800 when I left but I couldnt trust anything he said so I passed.
Stay away from this joker
1998 HONDA ACCORD EX 5SPD COUPE GAS SAVER
Old Mar 13, 2012 | 12:34 AM
UhOh's Avatar
good you walked
almost like maybe it was a high mileage unit after all and seller managed
to replace instrument cluster just before trying to find the right sucker
freshjiv
Sep 24, 2012 02:42 PM
jason.sloan0519
Aug 12, 2009 09:22 PM
chakwalian
Jul 6, 2009 09:44 AM
maverick777
May 20, 2009 01:10 PM
pawel
Oct 19, 2007 12:51 AM
