Bypass resistor box
Old Mar 30, 2008 | 11:21 PM
kenneyd's Avatar
Default Bypass resistor box
How do you bypass the resistor box, to use sat. injectors? I have a 94 accord and a f23 installed in it, and want to use the f23 injectors, because my injectors are leaking.
Old Mar 31, 2008 | 04:20 PM
finch13's Avatar
Default RE: Bypass resistor box
If you swapped ECU's when you swapped the engines you should have no problem running the injectors. What is the resistor box? Is your ECU chipped?
Old Mar 31, 2008 | 08:11 PM
kenneyd's Avatar
No I did not keep the ECU from the f23, I have my same ECU, and theresistor box came with my car. I just need to know how to bypass the resistor box, so i can run the injectors.
Just-Some-Guy
Oct 9, 2013 01:01 PM
RobinsonRicer
Jul 9, 2013 12:05 PM
2Hondas
Jun 10, 2012 09:41 AM
bglovept
Nov 8, 2010 02:37 PM
04SatinAccordTX
Jul 9, 2008 12:07 AM
