A/C Cold Air For Only 3-5Minutes
Old Jun 28, 2011 | 09:54 PM
renorains's Avatar
Default A/C Cold Air For Only 3-5Minutes
After starting the car and turning on the A/C, I get about 3mins of cold air and then i get ambient temperature air from the vents. In order to get cold air again, I have to turn off the car for a few minutes. Any ideas on what is going on with my car??
98 Honda Accord 2.3L Automatic 4cly.
Low Side: 25 PSI / High Side 180 PSI / Amb 97 degrees / Both Fans on / A/C Clutch is Engaged , I block off heater hose to Blower and checked relays and fuses for the a/c system.
Old Jun 28, 2011 | 10:23 PM
Tek310's Avatar
needs more r-134
your pressure is low. if im correct low side should be around 35-40psi and high side 250-300
it has to do with the ambient temp but i have misplaced the math.
i would check for a leak on your hoses, at the compressor, condenser, and receiver dryer. would like like a oily build up and dirty
what was your temp reading from your vents? stick a thermo in your center vent with your ac on max and on recirculate after 10 mins at 1500rpm take the temp reading.
meazz1
Dec 15, 2017 07:35 PM
drugrep
Jun 3, 2013 09:32 AM
bigbadbuff
Apr 17, 2012 12:56 PM
beagle
Sep 25, 2011 08:06 PM
accord962
Jun 24, 2009 04:28 PM
