A/C Compressor Protection
I bought an '09 Accord with 190hp 2.4l earlier today and before purchasing it the dealer replaced the A/C compressor on it because road debris hit the old one and cracked it causing it to fail. Did anyone do a DIY on fabricating a homemade protection for the A/C Compressor?
I would think the compressor is under the splash shield and is protected. Do you mean the a/c condenser was damaged?
i was surprised to see A/C compressor fail at such a low mileage. I did some research and apparently the road debris enters the engine bay compartment through the opening in the front bumper. If debris has enough weight and velocity it hits the A/C compressor and cracks the housing. The compressor sits low and is right behind the front bumper. From what I read on the Internet it appears to be a common issue on Accords.
Damage from debris "if" it happens, will usually be to the condenser, not the compressor.
Refer to these other threads for some info.: https://www.hondaaccordforum.com/for...ndenser-46420/ https://www.hondaaccordforum.com/for...l-issue-59681/ |
I know that "if" damage happens it's usually to the condenser, but there was a class action lawsuit against Honda for a design flaw where road debris enters the front bumper opening and damages the compressor, not only condenser. The Accord I bought had to get new compressor installed because of road debris damage.
The class action lawsuit alleges that the Odyssey is unduly prone to damage to the condenser from road debris, and that the CR-V and TSX suffer excessive failures of compressors.
Honda will also make available a screen that will protect the air conditioning condenser in Class Members’ Odyssey from road debris damage. Honda will reimburse Odyssey Sub-Class Members for the purchase price of the screen (up to $35.06) as well as reimburse $20 of the labor costs associated with installing the screen if it is purchased and professionally installed on an Odyssey Sub-Class Vehicle.
| All times are GMT -5. The time now is 09:11 AM. |
