A/C Control Trouble
My 2001 Accord has 5 settings for the vents. 0 in which no air really blows out, 1 2 3 and 4. While driving tonight i noticed that setting 1,2 and 3 don't work. 4 works fine but it blows way to hard and is to loud to only have that option. All the other setting act as 0 acts. Does anyone have any idea as to what the problem could be? Can i fix it myself?
Please Help!!!
Please Help!!!
I'm confused.
Is the blower motor - the one that pushes air out of the vents - blowing. Are you saying it only works in the "high" setting?
Or is the vent control - dash, defrost, feet, ect - not changing or only changing to certain positions.
yes sorry its the blower motor it only works on the highest setting, if its the resistor is that expensive to fix? is it easy to do it myself? or am i best just taking it in somewhere?
I think if you remove the panel below the glovebox, you can see the bottom of the blower housing. Look above the left toes of the passenger, if you're lucky you might not even have to remove that panel.
MinnesotanHonda
Feb 24, 2010 10:26 PM
raf105
Sep 28, 2007 02:55 PM
greenbean
Sep 21, 2007 03:14 PM
I think your understanding of the issue is correct....that was one thought when I posted but wasn't awake enough.
