A/C Control Trouble
Old Mar 24, 2013 | 12:34 AM
JOSHENATOR's Avatar
Default A/C Control Trouble
My 2001 Accord has 5 settings for the vents. 0 in which no air really blows out, 1 2 3 and 4. While driving tonight i noticed that setting 1,2 and 3 don't work. 4 works fine but it blows way to hard and is to loud to only have that option. All the other setting act as 0 acts. Does anyone have any idea as to what the problem could be? Can i fix it myself?
Please Help!!!
Old Mar 24, 2013 | 10:43 AM
I'm confused.
Is the blower motor - the one that pushes air out of the vents - blowing. Are you saying it only works in the "high" setting?
Or is the vent control - dash, defrost, feet, ect - not changing or only changing to certain positions.
Old Mar 24, 2013 | 12:01 PM
If it's the blower-speed setting, that's classic for a bad blower resistor (#7 in the picture).
Attached Thumbnails A/C Control Trouble-2001-blower.jpg
Old Mar 24, 2013 | 12:11 PM
Jim, now that I re-read this with more coffee I think your understanding of the issue is correct....that was one thought when I posted but wasn't awake enough.
Old Mar 24, 2013 | 02:46 PM
JOSHENATOR's Avatar
yes sorry its the blower motor it only works on the highest setting, if its the resistor is that expensive to fix? is it easy to do it myself? or am i best just taking it in somewhere?
Old Mar 24, 2013 | 03:37 PM
I think if you remove the panel below the glovebox, you can see the bottom of the blower housing. Look above the left toes of the passenger, if you're lucky you might not even have to remove that panel.
Old Mar 24, 2013 | 04:02 PM
JOSHENATOR's Avatar
awesome thanks again
Old Mar 25, 2013 | 06:38 AM
Random Cheese's Avatar
not expensive at all. Relatively easy fix. but I think you have to pull out the glove box.
MinnesotanHonda
Feb 24, 2010 10:26 PM
raf105
Sep 28, 2007 02:55 PM
greenbean
Sep 21, 2007 03:14 PM
95EXV6
Jun 27, 2005 08:21 PM
Getsch
May 24, 2005 07:52 PM
