a/c help
Old Jun 23, 2006 | 08:35 PM
joshua0221
Default a/c help
Well, my girlfriend has a 2000 honda accord. It's the 4-cyl version. The problem is that the blower only works when the **** is set on the "4" (the highest setting). It ONLY works on 4 whether it's a/c or heat. What could be the problem?
Old Jun 23, 2006 | 08:45 PM
sir_nasty's Avatar
Default RE: a/c help
sounds like the switch is bad... My friend had a Nissan that did that exact same thing... I'd pull it out and get a voltmeter and test it but I'd almost bet that if the wires are connected it's a bad switch.
Old Jun 23, 2006 | 08:58 PM
Chiovnidca's Avatar
ORIGINAL: sir_nasty
This is a honda though, it's more likely to be the power resister. They can be checked with an ohm meter. It's easier to check the blower switch from there too, instead of pulling it out of the dash.
Old Jun 23, 2006 | 09:26 PM
YeuEmMaiMai's Avatar
this car, does it have the auto climate or the normal system?
Old Jun 23, 2006 | 09:35 PM
joshua0221
Thanks for all of your advice. I'll check it tomorrow morning.
ORIGINAL: YeuEmMaiMai
What's the difference?
Old Jun 23, 2006 | 09:38 PM
if it is the normal system, replace the blower resistor. If it is an auto climate control unit, ask DH what to do.
Old Jun 23, 2006 | 10:19 PM
Chiovnidca's Avatar
ORIGINAL: joshua0221
The climate control system doesn't have a "4" setting.
Old Jun 23, 2006 | 10:58 PM
deserthonda's Avatar
some people have already hit it on the head.. most likely it is the blower resistor..
it is located under the dash next to the blower motor motor, plug has 4 wires going to it . .blue,,, blue/red.... blue/yellow.....blue/black.....
Old Jun 23, 2006 | 11:16 PM
isnt the fan on the automatic have variable settings versues 1-4 settings of the manual unit? I thought EX came standard with auto climate control?
Old Jun 23, 2006 | 11:24 PM
I do not think his car is an EX ..
