a/c help
Well, my girlfriend has a 2000 honda accord. It's the 4-cyl version. The problem is that the blower only works when the **** is set on the "4" (the highest setting). It ONLY works on 4 whether it's a/c or heat. What could be the problem?
sounds like the switch is bad... My friend had a Nissan that did that exact same thing... I'd pull it out and get a voltmeter and test it but I'd almost bet that if the wires are connected it's a bad switch.
ORIGINAL: sir_nasty
ORIGINAL: joshua0221
Thanks for all of your advice. I'll check it tomorrow morning.
What's the difference?
ORIGINAL: YeuEmMaiMai
this car, does it have the auto climate or the normal system?
some people have already hit it on the head.. most likely it is the blower resistor..
it is located under the dash next to the blower motor motor, plug has 4 wires going to it . .blue,,, blue/red.... blue/yellow.....blue/black.....
isnt the fan on the automatic have variable settings versues 1-4 settings of the manual unit? I thought EX came standard with auto climate control?
I do not think his car is an EX ..
