A/C issues
Old Feb 15, 2011 | 11:48 AM
91sihatchback's Avatar
Default A/C issues
my mom has an 02 accord 4 cylinder and her clutch fell off her a/c compressor i got the bolt from honda to get it back in i was wondering if there were any washers or anything i need and i was not able to find a diagram anyone have a link for that
Old Feb 15, 2011 | 04:53 PM
The bolt you bought was #6. The shims come as a set and are #11.
I would install all of the shims. If the clutch does not spin with the compressor pulley when you turn on the a/c, I would remove a shim, then retest.
Old Feb 22, 2011 | 12:11 PM
this is what i got from honda does that look rightA/C issues-dscn4219.jpg
Old Feb 22, 2011 | 03:21 PM
The c-clip on the right is #3 in that picture. It holds the pulley to the compressor. If the pulley is held in place, then you don't need that clip.
The bag on the left looks like the shim set #11 that you will need to put inside the clutch plate when you install it.
Old Feb 22, 2011 | 06:47 PM
ok thank you so much
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
msheehan
Mar 31, 2005 01:18 PM
