a/c Kit?
Old Feb 20, 2008 | 09:28 PM
ayisyen
Default a/c Kit?
Hi Guys,
I was contemplating doing some ac work in my car and was looking for a kit to do the job. I wanted it to be as cheap as possible while still allowing me to do a decent job (I'm probably not going to use it very often). I found this kit on ebay:
http://cgi.ebay.com/ebaymotors/R134a...mZ330212728996
I'm kinda new to this and want to learn in the process. I just want to know if you guys think this will allow me to do everything I need, which is to discharge the system to fix a leak and recharge. Please let me know your opinion. Thanks in advance,
J.D.
Old Feb 20, 2008 | 10:14 PM
oma93's Avatar
Default RE: a/c Kit?
Looks ok to me. You'll have to fix the leak first of course. And you'll need the refrigerant and oil.
Old Feb 20, 2008 | 10:29 PM
ayisyen
ORIGINAL: oma93
Thanks for the answer... So basically, the process would be to discharge the system, fix the leak and then vacuum and add refrigerant and oil?
J.D.
Old Feb 20, 2008 | 11:17 PM
oma93's Avatar
Exactly.
Old Feb 21, 2008 | 06:40 PM
There's a lot of good instructions and reference material at autoacforum.com.
I bought my first set of gauges, built a vacuum pump, and purchased a leak detector many years ago. Thankfully, I haven't had to do AC work frequently, but when the need arises, it's very satisfying and rewarding financially. Plus you get the satisfaction of knowing it's done correctly.
Basically all AC systems are the same mechanically (controls vary), so once you've learned the basics you can work on any car.
Old Feb 21, 2008 | 08:47 PM
ayisyen
Thanks for the reply's guys. I really appreciate it.
I will thech the autoacforum website to get some info. It seems very interesting and I look forward to starting fixing my system!
HondaAccordEX94
Feb 2, 2010 12:20 PM
Eworx
Jul 22, 2008 11:07 PM
honda2007accord
Mar 1, 2008 01:23 AM
thunder_x
May 7, 2006 12:57 PM
