A/C problem on 2000 Accord
Old Jun 11, 2009 | 11:52 PM
Gbav1's Avatar
Default A/C problem on 2000 Accord
My problem is the ac unit will be working fine for weeks, then al of a sudden the the ac control lights will go off and the compressor, etc. shuts off, but the fan inside the car will continue to run. May stay off for 5 minutes, or 1 hour, than will come back on by itself.
Any Idea's where to look and there location?
Thanks in advance
Old Jun 12, 2009 | 12:05 PM
When this happens, the AC control circuit (not compressor) is opening somewhere. When this circuit opens, the ECM disables the compressor by denying ground to AC relay.
There are a number of possibilities; AC diode, faulty AC switch, or faulty hi/lo pressure protection switch. Looking at wiring diagram, a faulty AC on/off switch seems most likely since light goes off when problem arises. It appears that only way for light to go off w/ AC switch is ON is a faulty switch. Heater control panel must be removed to access/test/replace this switch.
Above is based on manual AC control system, not Auto Temp Control.
Old Jun 15, 2009 | 08:44 AM
Gbav1's Avatar
how do you remove the control console from the dash to get to switch. I removed the 2 bootm screws and pulled out the bottom, but don't know how to unlatch the top by the vent /clock section?
Old Jun 15, 2009 | 11:47 AM
I am not familiar w/ 2000 Accord and you can do a lot of damage by forcing parts. I would suggest looking at autozone.com for your vehicle repair manual for guidance. Perhaps someone else on this site can provide guidance.
Old Jun 19, 2009 | 12:23 AM
Gbav1's Avatar
Default Fix
You were spot on with the problem. To remove the center of the dash, it was 2 screws below the radio section, and 1 screw that was behind the dashboard clock. Just unplugged the old control unit, and replaced witha NIB factory unit ($255.) reassembled, and life is good again.
Thanks again Gbav1
Old Jun 19, 2009 | 01:04 AM
janu03's Avatar
Banned
A/C condenser prone to damage by road debris with the 2003 Honda Accord. CarComplaints.com has 14 complaints about this AC / heater problem
Old Jun 19, 2009 | 11:00 AM
00AccordLX5spd's Avatar
Registered User
He has a 2000 Accord. That issue does not apply.
Old Nov 26, 2010 | 06:14 PM
Atrucancer's Avatar
I am having the same issue with my unit. What exactly did you purchase to fix the problem. Please help
kellysa111
May 1, 2009 08:35 AM
friskoesupastar
Jan 24, 2009 03:46 PM
kissbally78
Dec 25, 2008 07:36 AM
XYKD
Dec 17, 2008 11:30 AM
mlaccord
Jul 31, 2006 12:22 AM
