A/c problem after swap was done
Old May 3, 2012 | 10:02 AM
DIRTY_ROB82's Avatar
Default A/c problem after swap was done
Hello guys,
about a year ago i swapped a 98 h22a engine into my 1998 Honda Accord Dx 4doors 4cyl. The person switched my obd2 to obd1 in the process.
Since it was winter and i didnt use my A/C. Before my swap the a/c was working perfect. Ever since I did the swap and that i finally turn on my a/c,everytime i put on the A/C that car stalls at a stop sign. The idle stays steady but the car just stalls if i dont press on accelerator. When im driving on the highway the A/C works just fine but as soon as i let go of the gas when i have to stop at a light or a stop the car just stalls or hot air comes out if i dont press on accelerator.
I think the tech put on my old compressor from my Accord into the h22a engine.
Anybody have any clue about this problem or maybe i should get the compressor from an actual prelude since its a pelude engine?
Thanks for your help.
Old May 3, 2012 | 01:05 PM
Roader's Avatar
Probably nothing wrong with the compressor since it works well at highway speeds. Does the car stall at stops if the A/C isn't on? What's the tach read when it's idling & no A/C?
Old May 3, 2012 | 01:12 PM
ECU should compensate for AC compressor load by increasing idle air flow through the Idle Air Control Valve (IACV). Make sure IACV is working and clean. Check DIY section for cleaning instructions.
IF IACV is working make sure the base idle is set correctly to about 600 rpm =/- 50 rpm w/ IACV disconnected.
Old May 3, 2012 | 01:27 PM
Thanks for replying.
The car runs smooth when the a/c is not on. the idle stays normal. As soon as i press a/c button the car stalls right away if im not pressing on gas.
I will start by checking my air control valve like you said and il keep you posted.
Thank you very much for your help.
Jdm inspired
Nov 2, 2009 02:09 AM
CDelgado
Jun 13, 2009 08:39 PM
kellysa111
May 1, 2009 08:35 AM
accord4sroy
Jun 9, 2006 03:35 PM
theycallmerickjames
Apr 12, 2006 10:20 PM
