Calling (((hondaed)))
Old May 15, 2008 | 04:51 PM
blkhonda1999ex's Avatar
Default Calling (((hondaed)))
Hi Ed,
Thanks for your help about the Main Fuel Relay. I just bought a new relay and ready to put it on and I have a few question to ask you. Do I need to remove the panel underneath the steering wheel? if so, how doI remove that?What is the easiest way to get to the relay? I know there is a linkon how tobut I wanted to hear from you since you have alot of experience with the relay. Do I also need to remove the cable from the battery?
Thanks ED!
Old May 15, 2008 | 06:17 PM
Default RE: Calling (((hondaed)))
I guess hondaed is not around. Anyone then?
Old May 15, 2008 | 10:24 PM
poff1986's Avatar
You should be able to crawl underneath and disconnect it from under the dash without taking off any panels, you also shouldnt have to remove the battery terms, just make sure the keys out of the ignition, that will also help get rid of that annoying beeping sound while your under there...
HORSEPOWERJUNKIE2007
Jul 8, 2008 10:51 AM
Jun 10, 2008 12:43 AM
Diddy
Jun 3, 2008 10:21 PM
harley4jcs
Oct 1, 2007 08:52 PM
98Accord220HP
Jul 27, 2006 10:26 PM
