can bad battery cause SRS light to remain on??
Hi everybody. New guy. I have a 2000 Accord V6 and have been through the dealer battles as to why the SRS light stays on, several years ago. Finally learned of recall covering this and got reimbursed for the service $$.That was between 2003 and 2006.
Now, suddenly, the SRS light is back on. Honda dealer told me today that a "bad battery" - needs replacement - is the cause. Does this sound legit? All through 2003 - 2006 (see above) I never once heard the battery as the cause of the SRS light staying on. New Honda battery is "only" $138.
Thanks a lot.
Thanks a lot.
Chances are the battery isn't the cause of your SRS light being on.
What would cause the SRS light of a 2000 Honda Accord to come on and how can it be reset
Although it may or may not be the cause, a bad battery can cause the SRS light to be on:
May 2001 Honda Service News
A frequent source of SRS light on is bad switch in the seat belt latch. A dose of WD40 and some excercsing (latch/unlatch,...) may permanently cure the problem.
The following thread may help to extract the code.
http://forums.clubrsx.com/showthread.php?t=636707
Now, suddenly, the SRS led light is back on. Honda dealer told me today that a "bad battery" - needs replacement - is the cause. Does this sound legit? All through 2003 - 2006 (see above) I never once heard the battery as the cause of the SRS light staying on. New Honda battery is "only" $138.
Thanks a lot.
Thanks a lot.
bjr001
Aug 2, 2013 06:30 PM
c.schoch
May 18, 2010 11:39 AM
YeuEmMaiMai
Oct 17, 2006 04:32 AM
