Can't change selector from defrost
Old Jun 16, 2011 | 06:44 PM
skramer's Avatar
Default Can't change selector from defrost
I'm new here, but have been a Honda Accord owner for 20 years. I just recently bought a '99 Accord EX 2.3l with manual trans. A problem it has is that it won't change from blowing on the windshield. It won't change to dash vents or floor vents. The blower works fine and the AC works. Anybody have some words of wisdom for a forum newbie. Thanks.
Old Jun 16, 2011 | 07:02 PM
Suggest downloading the 94-97 Accord Manual from Online Manuals links in DIY forum. This should be similar to your vehicle. You can cross check at Autozone for your model to insure similarity.
There is a Mode motor test in the 94-97 Accord manual that should determine whether your motor is good or perhaps your control panel is faulty.
Check mode control motor under driver's side of dash. If you see movement, you may have damaged linkage to the vent selection door.
Old Jun 16, 2011 | 08:17 PM
When the vents stay on defrost, does the light change when you select a different vent mode?
Old Jun 16, 2011 | 08:35 PM
skramer's Avatar
Yes, the light changes, but the air still blows at defrost.
Thanks for the help so far.
Old Jun 16, 2011 | 08:57 PM
I think the "quickest" test will be to unplug the connector to the mode control motor (#5). You will need a volt meter to do the tests. The entire unit (#3) is under the dash towards the center of the dash.
This is based on the 94 manual, but yours should be similar. On the electrical connector, there should be one wire that has voltage with the key in the II position (blk/yel?). There may be one wire that is always grounded (closed circuit or zero resistance to ground). The other wires remaining will only be grounded if the proper mode is selected on the HVAC panel. In other words, only one other wire should be grounded. Another wire will be grounded when you switch the mode to say only the upper vents.
If you go through this and find that the ground is switching and have power, then you can replace the mode control motor #5.
Old Jun 19, 2011 | 07:48 PM
skramer's Avatar
Just an update on this, I think the climate control unit is bad. The lights started blinking and randomly all go off. When they go off nothing works except the fan motor. Anyone know where I can get one for less than $80 on ebay?
Old Jun 19, 2011 | 09:04 PM
You may be better off going to a junkyard. car-part.com will search junkyards and sort by distance or price.
You can also search forums for people parting out their accords in the classified section.
davecof
Mar 15, 2010 07:00 PM
watut
Dec 16, 2009 12:10 PM
moshlub
Jul 17, 2009 05:29 PM
diggerrigger
Oct 11, 2008 02:21 PM
dunorr
Apr 19, 2007 09:22 AM
