cant remove bolt
Old Jun 24, 2011 | 08:25 AM
jdm 94 cd7's Avatar
Default cant remove bolt
im trying 2 lower my car and the bolts at the bottom wont come off..the bolts under the hood came off fine but the problem is the bottom bolts holding the shocks to the axcel.how do i remove the bolts without stripping it?
Old Jun 24, 2011 | 08:47 AM
There is a self-locking bolt at top of the damper fork that locks base of strut to fork. Is that the bolt? It threads into fork and removes from rear. If truly frozen, suggest heating w/ propane or acetylene torch and applying an air impact. There may be access on front side to spray some penetrant on the end of the bolt where it threads into fork. If it twists off, you will need to locate a used fork. Heat works wonders.
If you mean the lower flange bolt that connect fork to lower arm, you may need to hold nut while turning bolt head. Here if truly frozen or cross-threaded, you can grind off the bolt head and drive the bolt out.
jramlow
Feb 10, 2014 07:47 AM
jdavidsmi
Apr 30, 2013 11:29 PM
theDex
Oct 14, 2012 10:49 AM
Jet sitter
Apr 7, 2012 07:29 PM
justinit
Sep 24, 2009 04:56 PM
