Can't remove flow control valve cap
Old Jan 9, 2016 | 10:59 AM
BlackLX4's Avatar
Default Can't remove flow control valve cap
I'm rebuilding the power steering pump and I can't remove the cap for the flow control valve. I have it bolted in the car to try and get it off, but I'm afraid I'm getting close to rounding out the hex slot for the Allen wrench. It hasn't budged a hair. I can't afford a new one, so I'm pretty stuck. Please help ASAP!
Old Jan 9, 2016 | 11:34 AM
Suggest heating w/ a propane torch. This frequently helps stuck bolts.
If unsuccessful suggest replacing the pump w/ used unit. Check car-part.com for salvage yards w/ part near your zip code.
Old Jan 9, 2016 | 11:55 AM
BlackLX4's Avatar
Rounded it out. Any way to make the hole a square one, or is that pretty much impossible?
Old Jan 9, 2016 | 01:11 PM
I think it is a 10mm hex that should go in there.
But now that it is rounded....decision point.
1. Is it really worth removing it?
2. A bone yard find might be an option
3 thru about 20 - Use a dremel and small cutting wheel and cut a slot and use a flathead.....is there enough of the "lip" on the outside to get a pair of vise grips on it.....
This is for a 7th gen but the PS pumps are pretty much the same.....some nice pic's and detail write up - https://www.hondaaccordforum.com/for...-accord-57704/
Old Jan 9, 2016 | 03:03 PM
You should be able to get an easy-out remover into the rounded hole. Did you apply heat? If yes, I doubt an easy out will work any better.
Old Jan 11, 2016 | 03:58 PM
BlackLX4's Avatar
Went ahead and got a remanned unit. I'll apply these tips if I ever have this problem again. Thanks again, guys!
Dale269
Sep 22, 2011 10:49 AM
AccordAnimal
Aug 11, 2010 08:04 AM
justinit
Sep 24, 2009 04:56 PM
Rob (215)
Sep 23, 2009 10:27 PM
thunder_x
Apr 23, 2008 02:40 PM
