Car runs rough and stalls
Old May 20, 2010 | 12:55 AM
Rcruz's Avatar
Default Car runs rough and stalls
Need help on my 2000 accord 4cyl. Car cuts out when I come to a quick stop or idle runs really low after I rev engine up. Would a weak fuel pump or clog filter cause this? Any suggestions?
Thanks
Old May 20, 2010 | 06:51 AM
You don't have a normal fuel filter. Check for problems with pump by measuring fuel pressure.
Idle problems can be caused by a few things...
Find & fix any vacuum leaks.
Make sure there's no air pockets in the cooling system.
Clean throttlebody.
Clean IAC valve.
Set your base idle.
Old May 20, 2010 | 12:41 PM
Rcruz's Avatar
Thanks for reply, Car runs great once you get going, If you come to a stop or sitting and hit the gas pedal and let go, Idle drops do to about 3 rpm and sometime dies out. Would it be a problem to adjust the idle screw on the throttle body? also is there a way to test the map sensor?
Old May 20, 2010 | 01:47 PM
The idle screw on the throttle body is for the base idle. It doesn't work well to set the operating idle with that because the IACV will be trying to work against you.
Old May 21, 2010 | 08:12 AM
Rcruz's Avatar
Thanks for info. I did bring the idle up a little and seems to work.
curmudgeon
Aug 31, 2013 11:36 AM
Slidesquad240
Nov 23, 2012 03:31 PM
Matthew Christopher Bucklin Sr.
Nov 14, 2012 08:07 PM
chris30721
Jan 6, 2011 08:06 AM
Accord Pete
Jan 31, 2010 02:50 PM
