Did head gasket car still runs rough n smokes
Old Nov 23, 2012 | 10:35 AM
Slidesquad240's Avatar
Default Did head gasket car still runs rough n smokes
94 Honda accord 2.2. Did a junkyard motor swap and it ran good for about 3 days til I noticed loss of power and white smoke from exhaust and milky oil. Did some research and found it could be the head gasket cheapest way so I did it and car runs like crap still has a lil more power but won't rev past 4k and oil isn't too milky not sure if it's from what was leftover in the crankcase from when I drained it. Also smokes but not nearly as bad when it first did. Any ideas? Cracked head? Bad rings? Any helP would be awesome
Old Nov 23, 2012 | 02:05 PM
jroxz44's Avatar
Almost A Senior Member
Bad rings would be my thought. And is the oil still filling up with anti freeze? Do a compression test and if everything comes back good. Try checking your intake manifold for leaks. Pure white smoke or blueish color?
Old Nov 23, 2012 | 03:07 PM
Silver6gen's Avatar
Do not run the engine anymore until you figure this out. You are risking serious damage to bearings and cylinders.
Do a leak down test
Old Nov 23, 2012 | 03:31 PM
No it didn't smoke today but did yesterday as it was a lot colder. I checked timing and it's out 180 degrees I'll see how that works
nickmg555
Mar 18, 2014 11:01 AM
Shag Wagon
Oct 12, 2010 03:37 PM
jackfast
May 15, 2010 09:16 PM
Accord Pete
Jan 31, 2010 02:50 PM
thunder_x
Jul 9, 2007 11:57 AM
