Car stalls out on v6 auto
Old Feb 6, 2008 | 09:45 PM
Jtweaz's Avatar
Default Car stalls out on v6 auto
every so often i would start my car (only like 5 times in 10 months so far) and it would sound like its choking then stall out... after like 2 or 3 times and or pressing the gas itll start and run fine..... 2 times it came up with a code that cleared itself after about 2 days and the other 3 times had no codes at all
im thinkin vac line or fuel issue but no idea where to start
Old Feb 7, 2008 | 10:07 AM
00AccordLX5spd's Avatar
Registered User
Default RE: Car stalls out on v6 auto
The next time it throws a code, go to AutoZone or Advance Auto Parts ASAP while the check engine light is on. Get the code number and post it here.
Some may be able to offer some help based on the description itself.
If it cranks, but sounds like it is "choking out" it sounds like a fuel issue to me. Possibly the filter screen on the fuel pump is clogged. You can access the fuel pump throughan access hole in the trunk. You will have to pull out the pump to access the "filter screen." The fuel filter is not separated from the pump in your model accord. That "filter screen" i described serves as the "fuel filter."
However, I do not know that it would throw a code if the filter screen was clogged. So I am interested in seeing what the code is....
Old Feb 7, 2008 | 06:40 PM
Jtweaz's Avatar
ill see if i can choke it lol
Old Feb 8, 2008 | 03:04 AM
HondatechAV6's Avatar
is it a 2000 v6 and the problem only happens in the winter months when it is unusually warm after a drive?
Old Feb 8, 2008 | 03:50 PM
Jtweaz's Avatar
well it started in like august n the last time was like 3 days ago.. i really cant say cuz i havent had it long enough but i had no issues during summer so u could kinda say yes
redchevy
May 20, 2013 11:41 PM
shula
Sep 8, 2011 03:10 PM
apogeeren
Dec 23, 2010 09:21 AM
98-Accord
Oct 24, 2010 11:15 AM
omnisip
Jul 19, 2009 09:59 AM
