car will not run on cold mornings, 2001 accord v6
Old Feb 26, 2024 | 03:04 PM
nomad2020's Avatar
Sounds like you are convinced that all the injectors are bad and you are also determined to replace them all,
I have seen injector leak but never seen all injectors leak at same time to keep car from starting , if an injector is leaking you will have a misfire on that particular cylinder
Any ho I sincerely hope that you are correct and the money on the injectors is well spent and fixes your issue
Old Feb 29, 2024 | 01:04 AM
eksine's Avatar
this is what I see when I pull out the first fuel rail the one closest to the bumper. This is an injector leak right? This explains why I have cold start problems right?. Also like I said this Accord is a 2001 v6 it has 260,000 miles on it. fuel injectors supposedly have 50 to 100,000 miles of Life on them so it actually could be every fuel injector leaking
I did some more research I suppose they're not leaking they're just clogged really bad the bottom o-ring is bad that's probably why
eksine
Feb 24, 2024 12:24 PM
Redneckgizmo
Dec 12, 2017 07:57 AM
tferstl
Apr 12, 2017 12:34 PM
danjel
Apr 8, 2008 03:04 PM
igotjshoe
Jun 6, 2005 10:48 PM
