car won't start
Old Sep 6, 2006 | 02:01 PM
herzy23
Default car won't start
Yesterday I left my lights on in my car. That was in the morning. I went to leave for work around 4:30 pm and the car would not start. We tried to jump it, with no luck. The jumper cables that we had used were not coded right. So they were put on backwards. Once that happened the car made a wierd sound. So we gave up on that. We tried another set of jumper cables and tried to start the vehicle. No luck. Nothing came on. The only thing that works in the car are the horn and the emergency flashers. This morning I came to work and tried another battery in the car. No luck with that either. I called the dealership and the man told me that I might have fried the computer in the car. We hooked a voltometer and it's showing that the battery is good. Any suggestions on where to go from here would be greatly appreciated.
Old Sep 6, 2006 | 04:25 PM
sir_nasty's Avatar
Default RE: car won't start
The first thing I'd check is to make sure that none of the wiring to/from the battery melted, next check all the fuses under the dash and the fuses under the hood, most likely you blew a main fuse under the hood somewhere
Old Sep 6, 2006 | 05:26 PM
deserthonda's Avatar
MOST LIKELY YOU BLEW A MAIN FUSE,, chk the main fuses first as adviced by NASTY ,,underhood fuse box
Old Sep 6, 2006 | 08:21 PM
mbo1985's Avatar
I don't think you blew the computer if that brings you any consolation. Yeah, like everyone is saying, check that big see through 80 (i think) amp fuse.
Sheri6889
Jun 17, 2015 08:19 AM
Thisisnate
Aug 15, 2006 10:47 PM
motoprego
Jun 27, 2006 08:14 AM
stevec
Jun 16, 2006 10:37 PM
