Car won't start
Car won't start
hey guys i know this will be an easy one for you.
I went to my car this morning use the alarm to unlock the doors but only the 2 doors unlock i thought nothing of it. I turned the ignitinon all the lights on the dash board came on but the car would not start. the head lights are on and the radio plays. it does't make any clicking sounds when you turn the keys the lights on the dash board just come on. I tried using the remote start just for the hell of it but got the same results. so i call me cousin to give me a jump, the car start fine.
this afternoon after leaving work the same thing happened, is that a problem with the battery or what.
Anxiously awaiting responses.
RE: Car won't start
alternator?
Also , could it be that there is a light that you keep leaving on. couple weeks back i left that dome light on while i was
vacuuming the rear seat and forgot to turn it off again so it drained the battery.
im sure you'll get more responses soon ,,
RE: Car won't start
Did this happen all of a sudden or did you notice that the starter would turn the car over slower and slower each time? I would take the car somewhere and have them test the battery for cold cranking amps. At least you can rule this out. Also make sure you batt terminals are clean.
RE: Car won't start
start by telling us the year and model,, and if it is a factory alarm
if it start when jumped
chk the battery cables, make sure they are clean, tight and not corroded.. is battery ok ??
have battery tested ...
RE: Car won't start
ORIGINAL: bhalistix22
the car is a 1998 honda accord, EX 4 cyl.
it starts right up when i get a jump starth
than it is either the battery or the cables
scorll up and read what i suggested
Sheri6889
06-17-2015 08:19 AM
txredrage
01-08-2014 10:52 AM
