Cars driving me crazy!!
Old Jan 30, 2010 | 05:35 PM
accord1989's Avatar
Default Cars driving me crazy!!
Maybe you guys can help, I have a 1989 accord LXi (I believe, the fuel injected one), and its been sitting in my backyard over the winter, I went to start it and the battery was toast, so I bought a new one, now when I put the new battery in it still wont start, I turn the key but nothing happens, dos'nt try to start over or anything.... Its probably something little or stuiped I messed up but any thoughts or opinions is really appreciated, thx.
Old Jan 30, 2010 | 08:51 PM
91excoupe's Avatar
if it's a manual trans, i'd check the clutch switch, if its an auto, i'd check the neutral safety switch... also, i've seen rodents chew wires and such on cars that sit for a while...
Old Jan 30, 2010 | 09:23 PM
Your starter isn't getting power or isn't working properly.
If you have a volt meter see if the small wire going to the starter has 12V when you turn the key to the start position. Touch + volt meter lead to the wire and - meter lead to a bolt on the valve cover. You will need an assistant to do this. If you don't have 12V, then follow 91's suggestion.
If it does, then hit the starter moderately with the handle of a screw driver. If the car starts, then the solenoids are likely worn out in the starter.
Old Jan 30, 2010 | 09:29 PM
91excoupe's Avatar
D'OH! (palmface) forgot about the obvious first step, lol... do what he said first, then if you have no voltage, what i said is the NEXT step... (ashamed) lol
jasonsaccord
Mar 26, 2008 08:52 AM
ramezalmualla
Jun 21, 2007 09:15 PM
thunder_x
Apr 16, 2007 04:34 PM
thunder_x
Jan 1, 2007 09:24 PM
MichaelEXL
Nov 9, 2005 07:37 PM
