Cel
Old Feb 26, 2010 | 11:15 AM
drummer1279's Avatar
Default Cel
Here is a konundrum for you guys.. Ceck Engine Light coming on randomly in the middle of driving. Not able to get a code because everytime I turn the car off and back on it might not come on again. the general running of the car is still ok (no rough running, knocks, grinds etc..) so Im confused. this has been going on a week.
Old Feb 26, 2010 | 11:21 AM
Backup fuse OK? If not, it would clear every time you turn off the key.
Drive so the CEL comes on. Leave the engine idling when you short the SCS connector. Maybe you can get the code that way?
Old Feb 26, 2010 | 11:31 AM
g22cd5's Avatar
Supper Moderator
If popping a cel the code should be stored in the ecu until cleared like Jim said.
I would try and reset your ecu. Let it idle without touching the gas and wait until your cooling fans kick on. Then drive the car like you norm. would when you see your cel pop. and see if it happens again.
Old Feb 26, 2010 | 11:46 AM
just checked the fuses. all are good, underhood and under dash. I tried the idling until the fans came on then driving and it seems that the only time the CEL does pop on is driving. and its not all the time.. O2 sensor maybe?
Old Feb 26, 2010 | 12:30 PM
Originally Posted by drummer1279
... O2 sensor maybe?
Don't guess, there's too many other possibilities. I think your time is better spent figuring out why it doesn't store a code. Or read the code after it comes on like I said.
Old Feb 26, 2010 | 01:19 PM
deserthonda's Avatar
have you checked if code is stored in the ecu by jumping the scs connector yet ??
Old Feb 26, 2010 | 03:48 PM
I have not checked it while the engine is running yet. I had to come to work. that will be on the to do tomorrow morning list
Old Feb 27, 2010 | 09:53 AM
and of course now that I post something for help it freakin quits popping on *sigh*
Old Feb 27, 2010 | 03:01 PM
hondadude's Avatar
Is the ground wire at the T-stat housing clean & tight?
Old Feb 27, 2010 | 03:21 PM
I have not checked that. I'll do that in a bit.
