CEL is ON again...
Old Mar 19, 2009 | 10:27 AM
status's Avatar
Default CEL is ON again...
code is p0171
2005 4 dr 2.4 liter, manual.
please help all wise and knowning techs.
Old Mar 19, 2009 | 10:40 AM
status's Avatar
i think the maf could be dirty, might clean that, theres no vacuum leaks and the filter is less the a month old,
any suggestions to clean the maf it said electronic dust cleaners, or brake cleaner.
Old Mar 19, 2009 | 11:12 AM
finch13's Avatar
Anything that evaporates quickly and leaves no residue aka brake cleaner.
P0171 - System Too Lean (Bank 1)
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor.
Possible solutions include:
  • In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect all vacuum and PCV hoses, replace if necessary
  • Check for a dirty fuel filter and proper fuel pressure
Old Mar 19, 2009 | 11:40 AM
status's Avatar
yeaah thats what i read, also on elite cm i read sea foam and a premium tank might also help. i assume i can get sea foam at an autostore
Old Mar 19, 2009 | 11:45 AM
finch13's Avatar
Yeah, it's like $6-$9 a can, and there's different kinds so read the label.
Old Mar 19, 2009 | 12:24 PM
cjdm98's Avatar
Yeah dont get the Sea-foam transmission fix like one customer of mine got,and put it in his gas tank.Poor guy.
Old Mar 20, 2009 | 08:01 PM
status's Avatar
so i was readin the back of sea foam, has any one tried to use it in the intake ,or vacuum system?
Old Mar 20, 2009 | 08:37 PM
finch13's Avatar
I usually use a syringe to put small amounts through the throttle body. It's very easy to stall the engine.
Old Mar 20, 2009 | 08:42 PM
status's Avatar
yeah thats why i kinda dont want to do it.
bigb609
Dec 27, 2011 07:18 PM
Jul 24, 2006 03:55 AM
Jun 2, 2006 02:24 AM
Apr 28, 2006 05:12 PM
adbraz
Jul 6, 2005 02:37 PM
