CEL is on...can't pull codes
Old Feb 23, 2010 | 01:48 PM
czhonda's Avatar
Default CEL is on...can't pull codes
I'm hoping one of you experts can help me.
I'm working on my brother's '91 Accord Wagon w/auto trans.
It has a replacement motor in it with 40k miles on it.
It has a new set of plugs and wires, and O2 sensor.
The check engine light came on last night.
He said it seemed to lose power.
I couldn't recreate it this morning, but the CEL is still on.
I jumped the blue plug under the kick panel, and turned the key to run.
The CEL will not flash it just stays solid. The battery, oil, and seatbelt lights are also on.
Any ideas on what I'm doing wrong?
Thanks!
Old Mar 3, 2010 | 10:39 AM
hondadude's Avatar
I would suggest you try a reset by removing the NEG battery cable for 30 seconds, then drive again to see if it recodes.
Have the anti-theft radio code on hand if needed.
You say "The battery, oil, and seatbelt lights are also on" is that all the time [engine running] or just when the key is turned on?
Old Mar 4, 2010 | 08:10 AM
czhonda's Avatar
Sorry, they are on with the key in run. I guess that means the ECU is good?
I took it to a "Honda mechanic", and he had never seen a "stuck" CEL before.
vetski179
Apr 13, 2015 02:27 AM
DisplacedMic
Mar 25, 2011 07:17 AM
d_zone21
Oct 17, 2008 12:32 AM
mck52689
Jul 17, 2007 03:40 PM
cj_trap_shooter
Mar 22, 2007 02:58 PM
