CEL and code P0441
Old Jul 24, 2006 | 11:19 AM
rdrx7
Default CEL and code P0441
97 accord V6. 165,000 miles. Check engine light came on over the weekend. Code P0441 92 EVAP Emission Control System Improper Purge Flow. Any suggestions as to where to start looking? Hond aplace wants $70 an hour to troubleshoot but I figured that someone here might get me going in the right direction.
Thanks
Old Jul 24, 2006 | 08:04 PM
sir_nasty's Avatar
Default RE: CEL and code P0441
first off if you have an evap canister that may be it or the lines might be plugged... also, make sure you gas cap is on tight (that can throw some weird errors too...)
Old Jul 24, 2006 | 09:20 PM
Chiovnidca's Avatar
ORIGINAL: rdrx7
Thanks
I've seen that code on 4 different cars. Haven't been able to reproduce the code on any of em and none have returned. Clear it and see if it recodes.
Old Jul 25, 2006 | 01:46 AM
poff1986's Avatar
there is a valve mounted on your evap canister( evap purge control solenoid valve...that mostlikely went bad..it takes about 30 min to replace and i have no idea how much it cost...pry OEM about 160 bucks napa or aftermarket pry about 80? could be wrong..
Old Jul 26, 2006 | 10:11 AM
rdrx7
I am going to check all the hoses in and around the canister and EGR valve for cracks or anything this evening. It does recode if I clear the ECU. Has new gas cap within last week. I will post what I find tomorrow about the hoses and go from there.\
Thanks for the help
Old Aug 7, 2006 | 10:20 AM
rdrx7
alright here is the update. took it to the Honda place and they checked out the expansion valve at the canister and it is good. Checked all the vacuum hoses in and around that area leading from the canister, etc. all are good and not clogged. Also when I reset the ecu and then when the light comes back on it seems like the engine loses power or misses. It is weird. Any other thoughts, suggestions, comments, anything? Thanks
Old Aug 12, 2006 | 11:57 PM
rdrx7
update - no hoses in or around the canister have any holes or damage. Any idea to number of sensors to the Evap System?
Old Aug 13, 2006 | 01:57 AM
Chiovnidca's Avatar
ORIGINAL: rdrx7
There's just one, the fuel tank pressure sensor. It's probably not your problem.
Old Aug 13, 2006 | 02:17 AM
deserthonda's Avatar
this is 1 that you might have to take to a dealer or a shop that specializes on Hondas
it could bew a # of things ......you need to diagnose step by step to locate the problem
could be the EVAP PURGE FLOW SWITCH,,,,,,PURGE CONTROL SOLENOID VALVE....An open or short in the wiring between PURGE CONTROL SOLENOID VALVE and the MAIN RELAY or even the ECM itself ..
Old Aug 25, 2009 | 07:49 PM
pepin
Default and then
and then what can i do
krnluve24
Nov 12, 2014 10:07 AM
Kludge
Feb 19, 2013 10:03 PM
Khai Son
Mar 14, 2012 11:32 PM
teahtime
Aug 5, 2011 08:44 PM
Stener75
Jul 25, 2010 08:21 PM
