CEL on with no codes...
Old May 5, 2013 | 04:27 PM
fariskhan's Avatar
Default CEL on with no codes...
Hi, can any one please help me with the following issue. I have accord 98 2.3 and its CEL is on for 2 weeks or so. I tried taking the batteries wire off however, the cel did not disappear when I put them back on... I took the car to auto zone who checked for any error codes but it did not return any... any idea what can be the problem and what to do... thanks!
Old May 5, 2013 | 05:43 PM
Did Autozone reset ECM? Most won't do this. I'm not sure if you can reset ECM w/ battery removal. I've also seen some auto parts stores scanners that would not read codes, probably damaged pins. Suggest trying another auto parts store before getting too serious w/ other options; ECM replacement for instance.
Old May 6, 2013 | 05:33 PM
On 1998 you CAN reset by disconnecting the battery. Non-volatile memory started in 2003 (for USA Accords)
Most of the time, resetting won't make the CEL stay away. As soon as you start the engine and the ECU figures out that the problem isn't fixed, the light comes right back on.
Old Jun 14, 2021 | 07:18 PM
jools's Avatar
Would disconnecting the battery (to fit a new one) activate the CEL? -'94 4 cyl Accord
Old Jun 14, 2021 | 07:50 PM
It shouldn't. That would clear the ECU on a 94 accord.
jools
Jun 12, 2021 06:37 PM
93acc.ex
Feb 6, 2013 02:41 PM
remacts
Aug 25, 2012 02:16 PM
Cody_754
May 12, 2012 12:18 AM
czhonda
Mar 4, 2010 08:10 AM
