CEL pops intermittently
I drive a 94 LX. I replaced the radiator a few days ago, now the CEL pops on while I'm driving occasionally. I had the intake removed because the filter was sucking water, and I attached the filter directly to the manifold. now that the cold air intake is back on it continues to pop up. the engine pulls fine when the light is on but it idles slightly rougher. Any ideas?
I moved your help question to the General Tech Help section.
You can retrieve trouble codes by jumping the blue Service Check Connector under the passenger side dash. with a wire or small paper clip. Look in the Common DIY and Info thread "Sticky" at the top of the General Tech Help section for more info.
Then I would see that as either 3 or 12? And since you have a hot air intake I'd guess the "3"...but get the actual code.
Not all the time, there is some sensor on the OE tube but not to do with the MAP...some air chamber or something, too tired to look and that may only be on the EX's..sorry for being lazy.
For now, the code is gone.....wish you the best.
tpstaples
Oct 5, 2021 05:53 AM
LydiaEmily
Sep 29, 2010 01:05 AM
HondaRacer4Vtec
Oct 14, 2007 09:00 AM
