change your tranny fluid
Old May 10, 2006 | 10:50 PM
  #21
longhornjohn's Avatar
Default RE: change your tranny fluid
In regards to flush and fill-----I think the only way you can drain the converter is if it has a drain plug or at least American trannies are that way. If I am wrong about Honda then please let me know.
Old May 10, 2006 | 11:03 PM
  #22
Chiovnidca's Avatar
ORIGINAL: brad6841
Would this be the same for a 2002 V6 Auto?
Yes
ORIGINAL: brad6841
Is it also true there is no filter?
If the transmission has ever been replaced under warranty, or with a Honda reman tranny, it may have an external filter installed.
Old May 10, 2006 | 11:07 PM
  #23
Does anyone know if Wix makes an inline filter to install in the line that goes to the radiator cooler? Might be a good way to filter out the wear particles of the bands, clutches, etc.
Old May 10, 2006 | 11:09 PM
  #24
Chiovnidca's Avatar
ORIGINAL: longhornjohn
Honda torque converters dont have drain plugs. Hondas reccomended procedure for flushing is to: Drain and refill the fluid, run through the gears a couple times, and repeat 3 times. They dont reccomend power flushing.
Old Dec 17, 2006 | 11:45 PM
  #25
adamc44's Avatar
so if i was going to change my tranny fluid next week on my 94lx all i have to do is remove the bolt on the trans by the passenger side, let it drain, then refill with atf-z1? there is no filter i would fool with at all?how many quarts is required?any help is appreciated thanks adam.
Old Dec 18, 2006 | 12:08 AM
  #26
drummer1279's Avatar
yes it is that easy, and you dont need anymore than 3 quarts.
Old Dec 18, 2006 | 12:13 AM
  #27
and no filter, the filter is internal
Old Dec 18, 2006 | 01:04 AM
  #28
adamc44's Avatar
ok thanks drummer
Old Dec 18, 2006 | 06:08 PM
  #29
no prob
Old Dec 18, 2006 | 07:33 PM
  #30
deserthonda's Avatar
you can easily install an outside filter if you like,,,,,,,,,Honda reman trannies come with an external filter .....
Very easy to hook 1 up...... cut the return cooler line and istall the filter in the lines , make sure to have the flow of fluid going the proper way
