Changing brake fluid
Old May 23, 2013 | 10:33 AM
advait's Avatar
Default Changing brake fluid
Have a 2005 Accord with 53K miles.
Never had the brake fluid changed. The owners' manual recommends replacing it every 3 years.
Is changing the fluid necessary, and is there a way to tell if my car needs it?
Old May 23, 2013 | 10:39 AM
shipo's Avatar
Three years is a very good recommendation.
Is there any way to tell if it needs changing? Yes, time is pretty much the only factor; regardless of whether you've driven your six miles or six-hundred-thousand miles since the brake fluid was new, if you've gone over three years, it needs to be changed.
Why? Brake fluid is hygroscopic and absorbs water on a continual basis; this creates two issues:
  1. As the water content of the brake fluid increases, the fade resistance of your brakes decreases. Ultimately the brakes will start to fade in simple day to day driving.
  2. Water in the brake lines and down in the calipers and brake cylinders (if so equipped) WILL cause corrosion; keeping the brake fluid (relatively) fresh will eliminate or severely limit said corrosion.
Old May 23, 2013 | 11:02 AM
advait's Avatar
Default Many thanks
Shipo, many thanks for the response.
Old May 23, 2013 | 11:39 AM
shipo's Avatar
My pleasure.
nyaccodguy
Mar 17, 2015 06:38 PM
19962door
May 17, 2010 03:30 PM
Dr. Jimbo
Jul 23, 2009 03:54 PM
19Accord97
Mar 20, 2007 05:14 PM
jrcastro
Jun 27, 2006 08:06 PM
