Changing Radiator
Old Dec 3, 2006 | 11:47 AM
patcal's Avatar
Default Changing Radiator
I am replacing my radiator today in my 97 LX 2.2 5spd. I am under the impression that you can remove the radiator with the fans attached then swap them after it out. Is this correct? I am doing this in a few hours when it gets light.
Old Dec 3, 2006 | 11:51 AM
deserthonda's Avatar
Default RE: Changing Radiator
go to our DIY section there is a write up on HOW TO ,,,,,,but yes you can remove it with fans and swap them afterwards
Old Dec 3, 2006 | 11:58 AM
patcal's Avatar
Thanks. I had read the DIY but it stated the need to remove the fans & I have other info that says you can do it without. See, I have no access to lift the car to get the splashsheild off so I have to do it all from the top. I am going to install the lower rad hose before I lower it into place then I just have to tighten it after it is mounted.
Old Dec 3, 2006 | 12:04 PM
the reason that i like to remove the fans first , it makes it easier to pull the radiator out,, gives it more clearance especially on the 90-93 model .. 94-97 it is easier to remove it with fans ..
but you can remove the fans afterward ,, no problem , especially if you cannot raise the car in the air ,,,,,,,also if AT, remove the lines at the tranny
Old Dec 3, 2006 | 12:07 PM
patcal's Avatar
Thankfully, mines a 5 speed so I don't have to screw with those. Thanks for quick help.
Old Dec 3, 2006 | 12:10 PM
anytime ......,,,,,,,,,,,
Old Dec 3, 2006 | 06:03 PM
drummer1279's Avatar
I have a 92 Accord LX and I replaced the Radiator in mine a couple of months ago, I removed mine with the fans attached and swapped while it was out. It wasn't too bad, took me about an hour and 45 mins to do it all.
Old Dec 4, 2006 | 10:57 AM
patcal's Avatar
Well, I got it done in just under 2 hours. I did leave the fans on but I think if there is a next time I may try it by removing the fans first.
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
Rilex
Jan 22, 2013 06:09 AM
AccorDats
Aug 29, 2012 12:27 AM
hmr
Mar 28, 2012 10:49 PM
