Changing Rotors on 06 Accord
Almost the same as most other Japanese cars. For that matter most other cars, period.
If you look in the DIY section, there's probably a thread about the earlier "hub-over-rotor" brakes. Beginning with 1998 Accord front brakes are normal = much easier.
Remove 2 bolts for the caliper slide pins, remove caliper. DON'T let it hang by the hose.
Remove old brake pads.
Remove caliper bracket, 2 bolts, probably 17mm wrench.
Rotor might be stuck with rust so use PB Blaster or Kroil or something like that. Hit with mallet, or maybe there's a couple threaded holes to use. Find 2 bolts that fit (M6?) & use them as jacking screws to push the rotor off the hub.
ssc280
Apr 27, 2007 10:13 PM
deserthonda
May 12, 2006 04:06 AM
