changing trans fluid
Old Aug 9, 2009 | 09:50 PM
summer1942
Default changing trans fluid
Hello,
I have a problem to remove the trans plug. It is so hard .
On Honda Pilot engine, the trans plug is on the right side, therefore, I just using my foot and push in (from the front of the car) to remove the plug.
On Honda Accord engine, the plug is on the left, therefore I have to pull out (from the front of the car)
I guess I can jack the car up, but I wander do you have any trick to remove the plug without jack up the car ?
Thank you
Old Aug 10, 2009 | 12:03 AM
Put your year and model in your signature, so we know what accord you are working on.
Old Aug 10, 2009 | 06:38 AM
summer1942
Sorry, Honda Accord LX 2007 4 door sedan 2.4 L
Thank you
Old Aug 10, 2009 | 10:09 AM
Automatic or manual tranny? The plugs are in very different locations.
Old Aug 10, 2009 | 11:18 AM
summer1942
OOOP !!! Automatic.
I know where the plug is. However I can not remove it. Factory installed force is too much. Any trick for plug removal ???
Thanks
Old Aug 10, 2009 | 11:51 AM
If you're using a 3/8" ratchet to attempt removal, you are lacking adequate leverage. Try some of the following:
1) 1/2" Ratchet w/ 1/2x3/8 adapter
2) 1/2" Breaker Bar w/ 1/2x3/8 adapter
3) 1/2" Air Impact w/ 1/2x3/8 adapter
Weak link will be the 1/2x3/8 adapter. I've sheared these off before in other high-torque application. Let's hope some of above will work.
I've found this plug to be very tight but did manage to release w/ 1/2" ratchet and adapter.
Old Aug 10, 2009 | 12:12 PM
Couple Honda automatics that I've done for friends, that plug is very tight but snaps loose very suddenly.
I use a 3.8" breaker bar that's only about 12" long. Then I put a piece of pipe over it to make it longer...
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
felpz420
Jul 27, 2011 06:24 PM
19Accord97
Mar 20, 2007 05:14 PM
jrcastro
Jun 27, 2006 08:06 PM
