Changing trans fluid before maintence minder
Old May 28, 2017 | 01:58 PM
roman45's Avatar
Default Changing trans fluid before maintence minder
I have a 2011 Accord and I've only put about 31,000 on it in the first 6 years. My maintenance minder just popped up again and it's only for an oil change.
Any idea when or at what mileage the maintenance minder will recommend transmission fluid to be changed? Should I just wait until the maintenance minder tells me? Just wondering because of the length of time. I checked the fluid and it's just a little low, so I topped it off for now.
Thanks for any input.
Old May 28, 2017 | 03:50 PM
UhOh's Avatar
On a Subaru Forester with 225,000 miles I've changed the AT tranny oil 2x as often as recommended, and the tranny is now the most solid part of the car. So change it - if this is a car to stay with.
Old May 29, 2017 | 10:32 AM
See attached table from my 10 TSX. Yours should be same. It does not specify the mileage interval, but mine popped up on my 10 TSX at ~100K, although fluid appeared to have been changed (bought used w/ 86K miles).
From maintenance table change interval for heavy duty service is 60K, so no absolute necessity to change. However, cost of 3 qts of ATF is < $30 bucks so not much downside to an early change. It does require removal of underbody shield to access drain plug, which is no fun for DIY.
Old May 29, 2017 | 05:23 PM
roman45's Avatar
Thanks guys. This is exactly what I was thinking. Probably about 60K, but why not if you can.
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
felpz420
Jul 27, 2011 06:24 PM
summer1942
Aug 10, 2009 12:12 PM
wardykid23
Apr 17, 2005 11:55 PM
