check engine light
Old Jun 17, 2007 | 08:46 AM
skareb's Avatar
Default check engine light
Sorry guys I just can't figure this out. My problem is when I start the car after sitting a couple hours the check engine light comes on and will stay on till the car is turned off and back on again. In othere words I can literally start the car wait a few seconds till the light comes on shut the car off and start it again imediatly and the light goes out. Am not sure what this could be cause if I drive with the light on it drives no different then if the light is off. Any suggestion are greatly appreciated.
Old Jun 17, 2007 | 10:14 AM
hondadude's Avatar
Default RE: check engine light
Bogus Post ! ! ! 76 Accord has no Check Engine Light.
thought you fooled us heh?
Old Jun 17, 2007 | 10:50 AM
skareb's Avatar
Am not sure why you think it's a 76 . Doesn't matter though I guess I should have said It's a 92 Canadian car if that makes a difference, its also a 5 speed. Sorry for the confussion.
Old Jun 17, 2007 | 10:54 AM
hondadude's Avatar
Golly gee whiz, there is a difference between the 76 and the 92.....
Check this link and you can find the code stored in the ECU;
http://members.troublecodes.net/hond...ice%20conn.jpg
This link describes the codes;
http://members.troublecodes.net/hond...hondacodes.txt
Old Jun 17, 2007 | 11:45 AM
skareb's Avatar
Thanks man I will try that.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
