Check Engine Light
Old Dec 28, 2007 | 11:24 PM
HondaPhyco's Avatar
Default Check Engine Light
I recently cleaned out my EGR port, I removed some vacuum hoses, and unglugged some stuff to remove it but i put them all back. Until a couple hours later i was driving and my check engine light came on. I Checked the code and it gave me code 1-2. Some one help me......!>!>!>! O yeah! I looked under the hood and i had forgot to connect one of the hoses, could that be it? do i just need to reset?[:-]
Old Dec 29, 2007 | 08:21 AM
Default RE: Check Engine Light
Code 12 is EGR valve lift sensor circuit fault. It means a faulty input to the ECU from the valve lift sensor (short, open, or inconsistent perhaps) has been detected. Did you reconnect the EGR valve lift sensor? There is a lengthy diagnostic that must be stepped through to determine the fault source. If you download the 94-97 Accord shop manual (see DIY link for online manuals), you can perform the tests to find the fault.
Old Dec 29, 2007 | 08:27 AM
smaglik's Avatar
nice avatar.
Old Dec 29, 2007 | 10:23 AM
HondaPhyco's Avatar
Problem Solved. Went to auto zone, made sure i had the right code. Went to the mechanic where this guy wanted to charge me $55 to clean the valve. I told him that i forgot to connect the vacuum hose to the EGR valve and dwas driving the car. So last night i connected the hose, this morning i got the code cleared by another mechanic, FOR FREE WOOOO, could have done it myself. But hey save me the time. THANK YOU GUYS FOR YOUR HELP!!!!
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
