Check engine light is on
Old Feb 12, 2008 | 09:58 PM
jmehaff
Default Check engine light is on
Just replaced the timing belt, water pump and seals on my son's 97 Accord LX V6. Before disassembly, ensured TDC, during replacement ensured that nothing was disturbed, after reassembly started the vehicle, appeared to run fine and then shortly afterwards the check engine light came on. While engine was running, therewere no metal to metal contact sounds, no whinning belts, no other indicators. Any suggestions would be greatly appreciated.
Respectfully,
Jeff
Old Feb 15, 2008 | 11:52 AM
00AccordLX5spd's Avatar
Registered User
Default RE: Check engine light is on
Take it to AutoZone or Advance Auto Parts. They will read your OBDII trouble codes for free. the OBDII service connector is located behind the ash tray. Simple pull backwards on the ash tray to remove it and expose the connector. All they need to do is hook up their code reader.
Please post the exact code number here. It will look like this "P0123." Do NOT listen to the explanation they give you for why the code is shown. They are usually trying to sell you parts when they do that. Many times their explanations are dead wrong on a honda, however, the code is correct.
Old Feb 16, 2008 | 12:07 PM
jmehaff
Was finally able to make it to autozone, had the code read, P1361, the definition spit out was "Intermittent Interruption in TDC 1 Sensor Circuit." I certainly appreciate your assistance.
Respectfully,
Jeff
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
