Check engine light..
Old Sep 24, 2008 | 01:30 PM
anthonyj89
Default Check engine light..
Throwing up code PO401 EGR code. I've replaced the EGR valve, came on 25 miles after i put it on. [:@]I cleaned all the carbon out from underneath where the EGR valve sits, light came on two days later. Any ideas? Yes it has 183k on it and i don't really care for it being on because it drives perfectly okay. But good hell that light is annoying.
AND...
ABS light is on. I put it up on the lift at work, removed all the ABS sensors on all four wheels individually and cleaned them thinking that would do the trick and the light came back on..
Any ideas?
I'd really appreciate it. Thanks.
Old Sep 24, 2008 | 01:45 PM
Default RE: Check engine light..
What year, model, and engine do you have?
Regardless, the EGR ports are likely plugged up. This will block the exhaust gas after the valve opens up causing the check engine light to come on.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
