check engine light
Old Oct 21, 2008 | 10:29 PM
brooklyn1
Default check engine light
need help i have a 96 accord lx 136000 miles 1 owner always taken care of having problem with CEL coming on went to advance had code pulled replaced oxygen sensors did both just to be done with it two days later CEL back on went back to a different advance auto same code they exchanged sensor replaced again and went ahead replaced coolant sensor -thermostat -spark plugs two days later same problem any advice ?thanks
code PO141 bank 1
Old Oct 21, 2008 | 10:30 PM
Default RE: check engine light
Well it appears as one of two things:
either the wiring to the oxygen sensor is bad
or the cat is bad
thats my take on the situation
Old Oct 21, 2008 | 11:31 PM
I moved you to this forum...
Old Oct 22, 2008 | 02:16 AM
anna jennifer
My check engine light came on at 4200 miles. Has anyone else had a problem with their car? The dealer told me it was a common problem & he replaced a "switch." That's all the information I got.
ANNA JENNIFER
Promoter
Old Oct 22, 2008 | 02:34 AM
For both of the posters, post your error code on here (P####). The codes are stored when the engine computer detects a specific problem, so the problem can be efficiently diagnosed. Without the code, it is hard to give advice.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
