check engine light
Old May 25, 2012 | 07:21 PM
misterix's Avatar
Default check engine light
I have a 2000 Honda Accord 4 cyl. with about 98.8K miles on it. The check engine light went on recently and I took it to Autozone they said I have error code P1271, the mechanic there thinks it is variable valve timing (bank 1), he isn't 100% sure because there isn't a listing for Honda on his code checker. What do you guys say the problem is?
Old May 25, 2012 | 08:12 PM
Dr. Drivability's Avatar
doesn't look like it's a valid code for that ymm
Old May 25, 2012 | 08:17 PM
crispin's Avatar
Autozone doesn't employ mechanics.
He gave you the wrong code, that code is not valid.
Old May 25, 2012 | 11:28 PM
+1. Like Dr. D stated it is not valid for your model year (e.g., 2000 Accords don't have Accelerator Pedal Position (APP) sensors).
Old May 26, 2012 | 08:33 PM
misterix's Avatar
Default Pep boys
Took it to pet boys the code they gave me was P1259
Old May 26, 2012 | 08:40 PM
glramos's Avatar
every time i have a customer on the shop with this code only is because 1. don't change oil regularly .2 never check the oil level , in most cases a LOF fix this problem
here is a links to show how to inspect solenoid http://www.justanswer.com/uploads/ac...35227_vtec.pdf
http://www.justanswer.com/uploads/th...ystem_test.pdf
Old May 26, 2012 | 08:42 PM
That is a problem with the Vtec.
Vtec runs off of oil pressure, so the first thing to do is check your oil level.
Do you have a volt meter?
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
