Check engine light
Old Feb 25, 2014 | 03:44 PM
Bkosark's Avatar
Question Check engine light
I have a 93 accord lx that has a check engine light issue. When I start it up there is no light but when the engine comes up to temp the light comes on and it idles very low at that time. I removed and sprayed out the EGR valve and PCV valve was replaced to no avail. The issue is there is no stored codes in computer so when I go to read the flashes there are none. I'm stumped
Old Feb 25, 2014 | 03:58 PM
You should be able to jumper the SCS connector while it's running, so that way you can wait until the problem shows up.
Then you should probably make a new post with the error code, over in General Tech. That's where the "real" tech. questions belong. This is a kind of welcome & introductions board for new members.
Old Feb 25, 2014 | 10:40 PM
And Welcome and Thank You for joining.
Old Feb 26, 2014 | 04:43 PM
bayn8v's Avatar
Is it running any worse? Rough idle? You may have a bad O2 sensor.
Old Feb 27, 2014 | 06:47 PM
As Jim stated, don't guess. Get the code, then test.
And yes, thanks for joining.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
