Check Engine Light - 93 Accord Coupe
Old Mar 21, 2007 | 06:52 PM
AccordEX's Avatar
Default Check Engine Light - 93 Accord Coupe
TheCEL on my 93 Accord Coupe always comes on. I jumpered the 2 wires on the blue connector [above the kick panel] and these are the blinks I'm getting from the CEL....
1 long blinkfollowed by2 short blinks
Can someone decipher this for me PLEASE. Thanks!
-Paul
Old Mar 21, 2007 | 07:15 PM
hondadude's Avatar
Default RE: Check Engine Light - 93 Accord Coupe
Code 12 = EGR lift sensor; you might want to apply vacum to the EGR valve and be sure the plunger isn't stuck or sticking.
Other than that the 'lift sensor' on top of the valve could be at fault.
Your ECM set up does not monitor EGR flow, so it won't tell you the EGR passages are plugged up.
Old Mar 22, 2007 | 01:10 AM
Chiovnidca's Avatar
The egr control solenoid could be faulty also.
Old Mar 22, 2007 | 02:19 AM
AccordEX's Avatar
Thanks for the replies...I am now checking the EGR system. Hopefully, I can find the problem.
neomedic
Dec 18, 2013 01:36 PM
mickey4live
Jul 6, 2012 08:29 AM
horsebird
Dec 18, 2011 10:44 AM
wong_soso
Dec 5, 2005 11:03 AM
